You aren't going to max those turbos out with 100%. My 120% were maxed out(for my liking) with my 72/83 setup. I was running 2750us
Haha it's a built motor with 100% exergys and dual fuelers. The current setup runs well, the current 483 is just an older turbo so I thought maybe it would be beneficial to upgrade a little bit
I'm with Harbin and Trojan, with 100's your no where near the limit of your current setup.
What drive pressure, max boost (combined) and atmo boost only, are you seeing currently?
I'm seeing about 60 psi max 28 psi out of the big turbo. I'm at 7200 feet elevation tho
Your elevation isn't helping How smokey is it?
Haha it cleans up fairly well on 2350 us, smokes pretty heavy on 2500 us. Wasn't sure if a bullseye 483 or engineered diesel 484 would make any difference
I would go ahead and pressure test it anyway just to make sure. New or not sometimes stuff doesn't fit well.
By 96 you mean the turbine wheel? I would try and figure out the AR of the exhaust housing.
