Got a revised tune with my MAF adjusted down and it runs much better, way less smokey until the charger builds some boost and then the fuel comes in.
That's not why its not fueling as hard...........
......... these are TQ based ECMs and not MAF Based, I placed TQ limits on all of the tunes, the LB7 and LLY trucks are MAF limited, that went away on 2006 for the most part.
:thumb:
MAF is a very misunderstood sensor, I needed to prove to you that by altering the MAF sensor scaling you would see a difference in the data log, but it was not MAF that altered the fueling, it was the TQ limits I applied.
But I get tired of trying to explain this to customers, so I just did what I needed to do.
Everyone has an opinion, your inter cooler was cracked and may still be leaking boost, so it was smokier before because you had a boost leak.
Just let me know how you want me to change your MAF Sensor so it reads what you think it should on the data log and I will keep rescaling it until it makes you happy.
Or you can trust me and let me do what needs to be done.
