S475 single turbo ?
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Made this little plate to slip in front of the turbine inlet on my S475 when I got home from work........I loaded a tune with 0% vane position across the board too:roflmao::rofl: .............Results were interesting:D
MarkBroviak
DMax Junkie
2,151
549
Danville Indiana
I thought about that.......Danville 72mm would be the shit by itself. Could twin later with big atmosphere turbo.
Sent from my VS910 4G using Tapatalk 2
Oh but it is the shit by itself! I ran 115.9mph with it last night as a single turbo fuel only single pump on my truck. That is 1mph less than my best ever time with the twins! I am personally beyond impressed with it!
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Know what the drive and EGT's were
no, and don't wanna:roflmao:.........I was testing this purely to see spoolup/response. my plan, if I do this as a single, is to open the 2nd exhaust port at certain boost so spoolup lag is minimal. Turbo gasser guys are doing this with great results. I think we can too. This will actually be pretty easy to do/test, and I'm just looking to do something a little different even if it's wrong.
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
I can get a 1.10 housing for the 96 turbine if you decide to give it a go , for a pulling or comp truck i would give it a go , we have done a few 2.8 chargers with the same turbine and they have worked fine on pulling trucks with 3rd gear start , but never done any street testing though or any personally , it would make good HP though , what fueling mods do you have ? and is the motor built ?
Trent what do you think a setup like that would be capable of with 100 overs and dual fuelers?
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Keep in mind I was NOT going wide open, but boost was 45-50 total. Like I said earlier, the stock turbo is having an effect on how fast the spoolup is. To what extent I won't know until I get it removed and test more. I am also going to get my back pressure gauge hooked back up, and fix broken pyro gauge. If I don't like the end results, I'll put a different turbo back in the valley.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
48 psi boost, I dont have a drive preasure guage. My charger does have a billet wheel, I dont know if that raises boost or not?
06dmax
Aug 5, 2009
295
I have 83 with 1.0ar iv only seen like 35 peak with 45 overs stock cp3 for now
