Thought the II kits 475's were all 1.32 AR not 1.10...
I believe he was just going off the turbo he saw on Trent's site being sold as a single
Gotcha. Jag, why do you want to upgrade? Just because? Do you really need more air for a 11.99 pass??
You could just machine the cover and add the bigger wheel just another. Option
You would need to machine the cover and cut the pocket bigger on the compressor backing plate, then the S480 wheel would fit.
The turbo you are running now is an S475 with a T6 1.32 housing, 96mm turbine, 75mm compressor, and a race cover. The only difference between that and the S480 you are after is the comp wheel and housing. The easiest DIY option would be to buy an S480 race cover and comp wheel, remove your turbo, disassemble it completely, take the center section and new comp wheel to any decent machine shop to cut the pocket bigger, reassemble with the new comp wheel and cover and you will be ready to go. The nut is reverse threaded, when you put it back together use lok-tite and go finger tight then another 90*. The pocket should be the size of the back of the comp wheel + .030" for clearance (.015" all the way around), they will also need to fade the bevel from the new diameter down in. When you put it back together make sure there is no interference between the wheel and the compressor backing plate. I can get you all the parts and a rebuild kit if you want to go back together with new bearings and seals; or you could send me the turbo and I could take care of it all for you and send it back ready to bolt up.
I would also guess that you would see little to no gain. Your stock turbo's turbine is your biggest restriction right now, even at 0% vane position it can't flow the air that the S475 is pushing through your motor. If it was me I would be looking into sticking a nice S300 in there with an HTT stainless housing or a standard housing and big external gate.
your trucks gonna be sick Buitlngbd:hug:
Dustin im pretty sure he doesnt have a race cover. Its a v-band flange on the compressor outlet.......
how much we talkin?
i'm hopin to sell my s475 after i get the 480 to so it wont dig in my pocket to deep plus my truck wont have any downtime...
Long time Dustin lol havnt seen u on here in a while. Srry back to the thread
I'm lookin at around 3grand for a htt and install kit right?
