LB7: s475 over stock build
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
thought I would start a build thread on building twin over stock kit. After some hunting down, I will be getting most of the components here hopefully this weekend. Doing pretty much everything myself. The turbo should be here thursday, and the rest of my plumbing parts should show up before the week is over! so far, I have moved the coolant tank, removed the down pipe, and cut the flange off the down pipe so I can reuse that. here is some progress so far. After getting the down pipe out, I thought about shooting it 100 times, running it over 1,000 times and destroying it with a hammer, but I decided against it so I could use the flange.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
thanks for the picture! nothing to report for tonight. Put a 14 hr day in and had to help a buddy with some stuff right after work. This did show up tonight.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
^Where did you purchase that all from?
Columbiariver mandrel. I ordered all of the "hot" stuff from them. for the cold side I ordered the tubing from Race part solutions. I decided to go with aluminum on the intake, and between the turbos. I didnt like the thought of any rust on the inside of the tubing on the intake side of things.
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
What are you using for your oil lines?just finishing my 475/ihi but I need to decide what to do with the feed/dump.Will be running this wknd come hell or high water,Good luck with your build:thumb:
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
thanks! I am building them from scratch with parts from Summit. Got the flanges from Race part solutions. Running a 4 an feed line and a 10 an oil drain line. Got part of the hot pipe built. Its not pretty, but it should work ok. oh, and look what showed up tonight! I need to pop the cover off and get it smoothed out for some powder coating.
03spoolindmax
Nov 9, 2011
674
Mi
Why did you decide to run a 4an feed line instead of an 6an? Seems a little small iirc most kits run a 6an feed line
