S472/s488
moparkxracer
2,309
33
Out and about
I have thought about running that set up. But got a deal on what I have. The kit I am selling would not be hard to for a 472 in vis the 366. I was going to have Nathan built a Hotpipe for me so I could run a 468. But I went bigger all around.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
It'll be a laggy pig and you'll end up hating your truck. My cousin had a similar setup on his truck and it sucked ass. He now has a TCT 472 single and its amazing.
PACougar
2,105
41
El Dorado Hills, Ca
I would think if it's set up correctly and tuned right with the correct converter you'd enjoy it just fine. I'd probably run a more aggressive wheel in the 472 like a TCT to help get it spooled up quickly.
DMAXchris
Apr 28, 2009
2,273
Natrona Heights PA
Lemme ask ya this, what is your goal for your truck? I've noticed you've had a few threads about different turbo setups and really cant seem to make up your mind. Maybe if we know what you're shooting for we can provide better help.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
My s366/s480 towed awesome, spooled better than a s366 by itself...
I also built a s362/s475 kit for someone else and the spool wasn't noticeably better, a little quicker.
Build a large gated s366/gt55(91mm). We ran a gt55 91mm as a single on the pulling truck and it is far superior to a s483 in spoolup and power output, s488's are even worse on lag and don't have the turbine wheel to match the compressor. Or a gated s366/gt4788. A gt4294/gt5591 would be sweet but costly.
Xternal
Aug 31, 2012
306
S366/80 will get you there you already have a s366 so that is solved. Can we put this case to rest?
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
GT55's are a freak of nature on the quickness of spoolup vs the amount of HP produced.
Also a s366/(2)s363's would probably do what u want pretty well also...
