Okay so If I do decide to run an S400 on an otherwise stock motor which specs should I run??? And what do I need for mounting it up.
Also, I plan to run a big twin setup on the all out build and may use a GT42 in it.
Would it be a complete waste if I ran a 4202 with a stock fueling system or could I possibly supply just enough fuel to make it worth my while and not blow it up.
Also would I need headstuds for wither one of these setups or could I just squeak by.
The truck is a puller and daily driver however driveability never affects me much. And I never tow with it, I use the other 2 dmaxes for that.
