LB7: S366
yellowchevy
1,928
82
Louisburg, KS for now
Holy cow dude. I make 40 lbs all day lol. You have a massive hole somewhere lol. You check your drivers side intercooler tube? It rubs a hole on the bottom by the power steering.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
I have a new driver side intercooler tube so no leaks. My stock tube didn't have a leak either. I need to pressure test it one of these days.
Yellowchevy
03spoolindmax
Nov 9, 2011
674
Mi
I have the same Borg Warner non gated. I see 30-35 on my daily tune and around 42lbs on max with stock cp3 and fuel. With around 1200* egts on a highway pull.
MAXX IT OUT
Neglected
Mar 1, 2013
1,781
Des Moines, Iowa
What are you guys seeing for MPG and cruising and towing temps with the S366.....I want to get a set of up pipes or make them as well as port my stock manifolds and turbo pedistal, and do a intercooler. My tuning may need some adjustment, because it seem like a have a couple of dead spots, mostly at lower speeds where I have high egts and no change in RPM's. Also my MPG likes to take hits very easly.
Porno Joe
513
South of Pittsburgh
The best mpg I have seen out of my billet 366 is 25.2. That was on some back roads going just fast enough to hit 6th.
Cruising on flat highway a month ago I saw a range of 19-22. Cruising at 70 my egts are like 650ish.
Highway with lots of hills I am usually around 18.
A tank that's 100% city will be anywhere from 12-15.
My average on my DIC reads 17.3 and my app I use to track each fill up hand calculated reads 17.2.
I had a dead spot in my charger at like 5 psi. Turned out to be a boost leak. My y bridge elbow was missing a chunk at the bottom I upgraded to a solid bridge to fix the leak and my charger spools much better.
I did notice my charger doesn't really like driving in my low hp tune. Truck is smokier, gets worse mileage, and just seems lazy. Running on setting 2-3 it's much better
MAXX IT OUT
Neglected
Mar 1, 2013
1,781
Des Moines, Iowa
My truck doesn't like low power tunes ether. My brothers complain about throttle response....Press down a little on the peddle and you start off like normal, then the turbo spools.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Best I have got with mine so far was 31mpg hand calculated. I think the 366s don't like the smaller tunes cause they like the heat.
