S366 over S480 And 100% over Sticks...Too Much
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
S480
96mm
1.32 A/R
T-6
As for the S366, I don't have that info off hand. All I know is that this combo is supposed to be kick ass. Wish I didn't have a REAL day job so I could get this all built faster. All the parts from the machine shop should be back Friday and then it all goes back together starting Monday! Can't wait!
Nick
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
I don't see why not. If you're going with Dual CP3's you may as well have the injectors to go with it. I just went with 100% overs because I want all out performance.
Nick
S Phinney
4,008
Quncy, Fl
I can tell you that there is a big difference between a flowed and balanced set and just doing tips. Daily driving takes more precise fuel metering than WOT. That is why backflow on racing apps isn't as critical as DD. You may have some issues that you won't like. Good luck!
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
the 480 and the 5533 are pretty close aren't they? I think you might like that 4094 as the top turbo on you twins, sure seems to work well on mine. I have bigger exhaust housings I could put on but the boost and drive pressure seem to be fine so I think I'll leave well enough alone.:thumb:
catmenace
255
Already got the 366/480 and being installed. going to sell the 4094 with the whole kit. One other question is that I have the Airdog 165 so I am wanting to remove the factory fuel filter. Can you see any problems with that?
darkness
1,347
409
vegas
i dont see a problem with it. i took mine off when i put the twins on about 4-5000 miles ago with no adverse affects. i do have a big cat filter on my setup as well.
catmenace
255
You running a nicktane filter head for the cat filter?
darkness
1,347
409
vegas
no i run the much cheaper NAPA knock off :rofl::rofl:. ill post a pic here in a bit of the set up
Iceman56
Jan 19, 2009
867
Madison, SD
The 5533 is quite a bit bigger isn't it Ken? Isn't it like a 91mm inducer?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
The 5533 is a 91/133mm inducer with a 111 turbine. Can also be had with a 94/133mm inducer. The 480 is an 80mm inducer with a 96/87mm turbine. The 55 is a bad motha!
darkness
1,347
409
vegas
heres my set up. the NAPA part # is 4770
