S300 Kit. Wow.
JDub
607
Hooper, Utah
Just got one of HSP's S300 installation kits in to install on my 2002 LB7 to help with some future turbo testing. Absolutely amazed by the craftsmanship and fabrication skills from Joe and Dave. While the out of the box S366 works well for most applications, I'm hoping to show that for a little extra money making changes to the turbine wheel and compressor wheel sizes can make substantial improvements in towing and street performance depending on fueling and end goals...
13,712
773
Looking forward to hearing the results of your testing. Which turbo are you going to try first?
JDub
607
Hooper, Utah
Truck has a built trans, lift pump, stock fuel.
And will be starting with a cast 66 with a 70mm turbine wheel. Then we'll switch to a 64.5 FMW on the same 70 turbine. Then jump up to the box 66 and the 67.7 with the 73 turbine. Will most likely have to toss 30% injectors in at some point
JDub
607
Hooper, Utah
That's what the box 66 is. And personally I think for up to 600 horsepower ( or stock rods )that much turbine isnt needed.
JDub
607
Hooper, Utah
Change in plans on the turbo I'll be running. Borg Warner announced an all new line-up for the S300 crowd. More performance oriented stuff, 360-degree thrust washer and a new compressor cover design with intergrated speed sensor and boost port. They all have the Forged Mill Wheels in them too. Brand new 66mm and 69mm options to go with the 74mm turbine wheel. Said the 69mm flows almost 100lbs-min!
13,712
773
I've been meaning to start a thread about that new turbo line. Any word on when they're going to be released?
JDub
607
Hooper, Utah
I was told they should be available in January, but I'd bet it's closer to March-April. The 64.5mm already available and the new 66mm should be a great option for the Dmax crowd, the 66mm has a lower surge line than the current cast 66 and moves more air. Can't wait to try them out...
JDub
607
Hooper, Utah
minerigger
2,660
Casper, WY
I know I'm gonna have to either get rid of my billet 366 with the 80x74 turbine and go to a 363 or 364 with the 76x68 turbine or images have to feed it more fuel. At 5300 ft it's a pig and no fun to drive
skintback
Take this one to church
Mar 5, 2007
919
Florida
My 76 will be coming off for a 69/74 fmw when it's available then I'll be doing a 83 over it
That sounds like a mean street setup.
Is the 69/74 a T3 gated and what does FMW stand for?
I have the old 66/71/16ss gated T3 HTT its a powerful little turbo how does it compare to the 69/74FMW?
JDub
607
Hooper, Utah
Well, after two months of this kit sitting in the garage I may finally have some time to swap everything out in the next couple of weeks. Can't wait to try the S300 with the smaller 70mm turbine wheel out.
S Phinney
4,008
Quncy, Fl
The info that I have on the new turbos is there will be various formats and the prices are quite a bit higher than the current units. More than 2000 each.
