RUSTY = Need Help
13,746
821
Go to tunefiledepot.com and see if there is a tune there with the same OS as the one you pulled. Glad to see you got it working! :thumb:
SmokeShow
6,818
Lawrenceburg, KY
I checked that site Josh, and there is not a stock tune with the same last 4 digits of the OS as the tune I pulled from the 2001 truck...
SmokeShow
6,818
Lawrenceburg, KY
I have found a stock tune on here with the same OS... I'm going to try to use the compare tune function to check it against my 01 tune and see if mine is different.
They should be the same in the tables, right?
EDIT: As far as EFI Live is concerned by using the compare function, they are identical in every way. Caveat to that is that the tune I found on here is supposed to have High Idle enabled. That leaves me with a 2-part question...
A) Would that sort of difference not show up with the compare function because perhaps it only checks the tables such as tbiq, timing, etc.
or
B) Does it in fact check everything and somewhere along the lines my truck's tune has the High Idle enabled and therefore doesn't show any differences?
