Question: Running the lly at the track tonight.
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Ok quick question, I am
Going to run my truck at the strip tonight but it is going to be real hot,around 90 degrees. Now maybe a stupid question but is it going to have a real big effect on what I run since its going to be hot? I know with a turbo gas car or something people run into serious heat soak problems when it's hot out. What do you guys think?
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Bahaha, I'm sure you do Brian! In all seriousness. Will it hurt my times that bad?
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I'd assume by your location you're going to New England dragway?
The heat definitely won't help but I can't imagine it knocking anymore than a tenth or two off your times. And if your first time is anything like mine, they won't be fast or consistent anyways haha
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Well im pretty familiar with running the dmax, ran my 06 lly probably 25-30 times. This truck I havnt ran yet but basically set up the same as my other, same Trans kit and converter. It's lowered down. I'm pretty confident that it should be ok.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Well good luck. Post up if you ever get a chance to go to New England dragway on the Friday street nights. Be good to line up with another truck that wasn't in the 15s haha
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Hahah, same here man, most of the dmax's over at the valley are 16's. Kinda disappointing!
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I haven't tuned for my new turbo yet so I was getting check engine lights around the eighth mile and running 13.3 at 100 with the truck pulling fuel and boost bad. Everyone at the track was still amazed haha. Best part was the 14 and 15 second powerstrokes and 1 other duramax on a ppe tuner smoked like trains and I barely puffed off the line
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Hahaha. Yeah last year I had a few injectors on my 06lly returning to much fuel, still running 13.0@104. This truck feels much stronger so we will see! Atleast anywhere in the 12's ad I'll be happy!
5,818
the further your turbo is ran out of its map, the worse heat/hot air will affect your power
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Running it out of its map pushes hot air by itself. Definatley won't be as fast as if it was 50* outside with low moisture. Faster it is the worse it will affect it, but I don't think it will knock more than 1 off. If you have a bad time, you can still blame it on the moisture in the air though :)
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Ran 2 runs of 13.5@100??? Is it normal for tow haul is engaging half way down the track? Is that normal? Why does that happen? I am not starting in tow haul by half way down track it turns on??
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
what is your 60ft? running in TH isnt going to change your runs that much at your power level with stock turbo. what's your weight too? I ran a little faster ET at 98mph with the IronHyde truck I was working on a few years ago there at 7400lbs. are you dropping rail pressure?
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
1.92/1.74/1.80 but I should definatly be over 100mph trapspeeds. I should be atleast a 12.9. My stock 06lly did a 13.56 with stock Trans.. Lol
05chevy
1,086
I agree that you are probably losing rail. My LLY has went 12.40's on 95* days. I also leave in TH.
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Ok, so my best last night was a 13.54@100. Granted it was 95° out. Should have been atleast a 12.9! I know my fpr has been loping an getting worst. Not sure if that's the culprit, but goin to buy a v2 and log the rail pressure and see what's going on WOT. I will be also buying a lbz fpr to add aswell. Oh well
