Running Edge Starter Cable Through the Fire Wall
MADD*MAX
46
Alberta
What is the best option for running the edge starter cable through the fire wall on a GMT 900 truck? The smaller of the 2 ends still requires a decent sized hole to pass through. Secondly does anyone know if a typical pressure sending unit will work on Airdog where the low pressure light port is? I know its 1/8 NPT but it there enough room the fit the sending unit? Lastly does anyone have any good ideas for monitoring fuel temp on a CP3 converted LML? I'd really like to use the factory sensor but don't know the best way to tie it into the supply to the CP3. Right now the temp sensor is plugged in and just sitting on the driver side clamshell reading under hood temps.
MADD*MAX
46
Alberta
That is a possibility it just think it looks cheap. I'd rather drill a new hole but wanted to see where others have made one for accessories.
rcr1978
790
26
Spring Creek, NV
I usually pull the rubber plug out of the back of the fire wall grommets from the cab side pull the grommet into the cab and fish the wire through the same way the factory ones go through the grommet. Kind of a pain in the ass you will have to un-tape shit and undo some connectors but it looks clean when put back together in the loom.
