Rpm's at 70, 80 mph
02duramax
162
Yreka Ca
What is everyone's Rpm's at those mph?
I'm at 2200 at 70 and like close to 2400 at 80,
Egt's are at 700 and boost slightly around 6 psi.
Was reading I should be at 1700 Rpm's at 70.
Is this true?
Running a fast 100 tune with 265/75/16 tires.
Around 22.5 mpg
xtremebikr04
Jan 17, 2011
573
Vermont
Your not gonna be at 1700 rpm driving 70 with the truck listed in your signature. If you had a 6 speed then you would be around 1700.
5,751
Is this true?
Around 22.5 mpg
Your right on par for what you have. On 37s and stock gears I turn 1800rpm at 70 and 2000-2100 at 80.
btfarm
you know
Nov 25, 2010
387
Sandwich, Illinois
3 weeks ago in NW Nebraska
75 mph - 1950 rpm. Stock driveline 3.73
Sent from my SCH-I535
zeke38
Sep 29, 2009
172
33
Newark, IL
I'm at about 2k at 80 mph with my 305/55/20 tires and around 2750@120uploadfromtaptalk1384362440278.jpg
Sent from my SPH-L710 using Tapatalk 2
zeke38
Sep 29, 2009
172
33
Newark, IL
Sorry I was going 120 mph lol. Also it was a cell phone so that dosent help
519
Would timing on this tune be a little high?
what current timing while cruising?
pending load on the truck i run 7-13* of timing while cruising or about 1* per 100uS of pulse width
to make you feel any better... ;) .75 :1 OD 225/70/19.5(32") 4.63:1 gears 70 is just under 2500rpm
