roll pans with class 5 hitch
13,746
820
Are your roll pans welded on or bolted was looking into getting one couldnt find one I like besides a welded on roll pan with the plate to the passenger side instead of the center..
Mine is bolted on.
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
Mine is welded on. Ill post some pics of ny truck without the hitch on and the roll pan installed and my 5 inch exhaust when I get home this evening.
Sent from my PC36100 using Tapatalk
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
I'm also running a bigchevyhitch with a roll pan. I decided to have mine come from behind the plate for a cleaner look. I'm also running a stack so there's nothing hanging down in the back. Like said before James builds his hitches to your specs so it's just how you want it. Ive been sled pulling with the hitch pretty much all year with a good size drop hitch and have had no problems. I've also towed my other truck a bit running a 14" drop hitch with no problems. His hitches are built to last for sure
jheyob
305
Okeana OH/West Lafayette IN
Here's the class 5 that's behind my rollpan ;)
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
Yeah it definitely looks cleaner behind. But I always am pullin something. Mainly bobcat trailers. To/ from job everyday. I also have a 5in exhaust w/ 6in tip that I'm worried will look dumb as hell now with the bigger bumper gone. Hope it looks alright.
I didnt think it looked bad?
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
No jake it looks good for sure. I am same color as yours just the 06-07 body style. I think you either have more body covering the tires and rear end or your truck is lower. And my exhaust is flat and not tipped down like yours. I may have to tip mine like yours after the pan and tuck it more cause yours looks good. I have thought about a dump over the axle in the middle also. I have to get my pan on now cause all your guys info and pics has me all pumped.
Jheyob I like the bracing u have. That f***er is strong lookin!
flyinelvis11
543
50
VG, IL (because my wife does)
X2 on the truck wayne. Looks awesome!
Thats a nice truck, Wayne. :thumb: Love the color.
thank you guys. i didn't like the color when i first got it but i couldn't pass up the deal. after 4 years it's growing on me...lol
man i LOVE that welded look. i may have to redo mine
2005LLY
Sep 18, 2011
379
How much do you trim out of the spare tire crossmember to make the hitch set up high enough
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I did alot more than needed. IIRC it was about right at the bottom side of the radious. You don't need to take that much. I have more than an inch gap now and I mounted my hitch on top of the frame rather then below. Saw zall works great! Found out after I ran out of griding wheels :roflmao:
flyinelvis11
543
50
lol, this sounds exactly like me! i took out three inches measured up from the bottom. i took out at least an inch more than needed too and i ran out of cut off wheels too lol
[/IMG]
2005LLY
Sep 18, 2011
379
What size of drop hitch do you think I should get? I have a 6" drop hitch now, But I will be towing a 35ft fountain lighting that with the boat and trailer weighs about 9,000lbs so I need a heavier duty hitch
