you are making well over 700hp that is amazing
I dont think so. Rob's dyno was around 668hp if I remember correctly!
Josh-Just the back seat, tail gate and spare. Im sure the twins and lift add all the weight back on though!
I was talking to Russ, but your truck is really light if you weigh that with your back seat still in.if you're talking to me Josh just my tailgate and spare tire. I weigh 220 also
Your lift must add a bunch. My truck was right at 6650 with the back seat, spare, bumper, hitch, and tailgate removed.Josh-Just the back seat, tail gate and spare. Im sure the twins and lift add all the weight back on though!
I just made my hitch last week to hide behind the roll pan. I have the plastic push rivets holding on my license plate, remove those and the reciever is right behind it. My pull hitch is alot closer to the rear of the truck now and sits higher on the frame. Mine is made out of 4"x4" square tubing with the reciever welding straight into the middle of it - weighs alot more than the factory hitch but with the rollpan still less than the factory hitch and bumper. And I bet when I pulled in at the Pro Diesel Challange debadged and lowered on 20s this weekend some people probably thought I was a spectator in a 2WD; when the slicks went on they probably thought it was street/strip truck; when the MTs, weight rack and hitch went on they probably just started scratching their heads.
i scratch my head everytime you derail a thread to cheerlead
I scratch my head everytime you derail a thread to cheerlead
shouldnt you be looking for a job right now and not on line?
So russ you gonna run it all year or put the bumper on during bird season?
I have one of each, I think the metal one is a little lighter, but not much neither one can weigh 10 lbs. the urethane one needed a bit of work to make it look ok, wasn't that well make. Metal one bolted right on no problem.I understand your saving a ton of weight by doing away with the stock bumper but I see they offer a steel roll pan and a urethane one. Which would be better? Is the steel roll pan made of thin steel so your not gaining much weight loss?
