Roll Cage Questions
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Putting a cage in my regular cab. Just wondering how guys tie the cage to the frame? Was thinking of welding a piece of rectangle tubing to the frame so the bars go through the floor to that.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Both my LB7 and my half ton are a 1 5/8 hole in the floor so the bar can weld to the frame. believe there has to be a 6x6" plate at the body joint as well
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
So weld the pipe to the frame like pictured? We was thinking like the other but a cleaner set up.
1,868
I have heard of people using outriggers off the frame for the lower mounts. Is that legal?
5,836
No need for a plate at the body, just at the frame. If it was a unibody it would be a different story.
You can use a square tube out rigger, radius tube or what ever you think will work and be the cleanest. I would gusset the tube to the frame if you use the tubing to frame (not a boxed square tube out rigger).
Triangulation and no dead nodes are your friend
