Rod and Piston weight matching
The Kansan
Aug 30, 2013
179
Topeka, KS
Hey guys i was curious where you would take material from on a mahle race cast piston and a crower rod to do weight matching for engine balancing? Im going to have my rotating assembly balanced soon and would like to get your opinions on that, Thanks
S Phinney
4,008
Quncy, Fl
Materials taken off the wrist pin will have to done by a machine shop. You can't do it with hand tools yourself. They are extremely hard. Materials can be taken from the skirt if necessary. That isn't the preferred way but it is OK to do if you know what you are doing. Hopefully you are letting a qualified machine shop do the work. The right equipment is a necessity period.
The Kansan
Aug 30, 2013
179
Topeka, KS
The machine shop that is balancing everything is doing it, I was just asking bc i was curious how it was done.
S Phinney
4,008
Quncy, Fl
Sad part of it is that most machine shops do not balance as close as you would expect. They may mix heavy pistons and light rods and so on. Talk in depth about that and your expectations.
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
Also make sure they are using a torque plate. Most machine shops dont have them for duramax engines. I had to buy one for mine.
battlegraduate09
Gearhead
Mar 18, 2010
610
This, some are just unqualified in general. I got a set of inline6 rods back from a local machine shop the customer chose that were junk. All weight machined off the cap, wrist pin bores weren't touched and they were out 7+ grams.
Be careful with your choices and double check all you can
The Kansan
Aug 30, 2013
179
Topeka, KS
Ok thanks for the info. The guy thats doing it is really sharp and has done machining/balancing for my dad and myself in the past but im gonna be a lil picky on this build do to the sheer cost of one of these engines. A lil different from a sbc/bbc to a duramax. Is getting within a couple grams of each rod/piston set reasonable? How close do you recommend getting them?
The Kansan
Aug 30, 2013
179
Topeka, KS
Engine machining is already done and was done with a torque plate and was align honed with main studs. So that part is already done.
S Phinney
4,008
Quncy, Fl
Get with 1 gram total. That would be +/- .5 grams. They probably would want to be off a little more but that is the general high performance spec.
