roadtrip....home
542
more like hauling ass home.. finally (first time since i came out in jun 05) waiting on last load of laundry to dry, eat then step off :) :fluffy:
replaced my worn out 305 that i had in there and put in a much fresher 454. the sbc bore is so worn out. the rings i put in ~50-60k ago dont seal. it needs bored out to go any farther :rolleyes: been working on putting the 454 in last 4 days it is def nice not needing to slip the clutch from a stop. est power of my bbc is 300/490 lot better then the 330/330 of the 305
look like it was OEM..... FO i know it need washed/degreased :eek: :rofl:
im head back along the I40 then cutting northeast @ OKC to st/ louis then east on 70 to home. should be home some time wenesday :driving2:
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Ohio boy
Hello Adam, If your a Ohio boy we need to get together sometime. It would be nice to meet you in person. As you know if your from here there is a lot of racing and pulling to do here. Jeff
542
Unless it's a good running Duramax.:p
it will soon have one :rolleyes:
coming to Ohio I'll guess?
where is home, Dayton area?
good luck.
south charelston is home
cool... ill shoot you a Pm when i get home either late tues aro some time wenesday..
so my little jalopey has manage 14-17mpg running ~80mph between 5,000-7200' 15gl tank doesnt go very far :baby:
spent last night in needles CA currently i am in vega tx just under 800 miles in 12 hours stopping ever 2 hours or so to refuel :( 1100 miles total....
542
avg 16mpg run 80-85mph.. lost the alt belt just south of indy this morning.... other than that im home.........
one a friend said not bad conisderint i put/threw the motor in:rofl:
ruffmanatv
Yeah, its got a D-Max!
May 9, 2008
3,640
46
Van Wert, OH
Glad to hear you are home safe Adam. Good luck with getting the D-max going now. Might see you at London, OH. Still debating wether to take the night off work.
