Ripoed motor mount, can i still bolt it?
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
I took my motor mounts out today and of coarse driver side is broke. (See picture) Passenger side is fine. So can i bolt both and out the ripped one on passenger side and good one on driver side? Or should i just buy merchant mounts?
moparkxracer
2,309
33
Out and about
I'd buy new ones and bolt them. If you have the money to spend then go for the merchant ones. They do have a little more felt vibration
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Ahh j said screw it and bought merchants anyone want to go half on the other one? Thinking i could save a bit of money and just run the driver side
5,808
I bolted mine ripped also, no issues. I can't afford even one merchant mount or I would:roflmao:
knowing your rough on that poor rig with a stick in hand :D, how is the metal that is not connected to the rubber holding up? is it bending up around the bolt at all? that was my concern when i first bolted my mounts so i bought a new one, then bolted it. i figured the little bit of rubber would help hold the steel down from bending but there again, i cant see it doing all that much.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Good question I'll have to check, I put 2 bolts in mine right where the two small holes already were, but had to grind the one bolt head to clear the frame. I've done a few "3rd" gear launches since then at 4200 rpm so if it's gonna do anything as far as bending, it probably already has. I know before it was ripped and the drive shaft was hitting the rear engine plate it was torqing over so bad. I know it's not doing that anymore, but I could maybe see the bolt heads trying to pull through or at least denting the metal like u said. I'll look and let u guys know
