Return line re-routing
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Ok so with doing the twins i need to get rid of the stock hard lines that run over by the FICM, the feed and return are part of one block and i'm getting rid of the stock feed.
So my question is what can i do to get that tiny return line from the injectors to go back to the 1/4" rubber line in the valley w/o having to use that block?
Thanks
kyle
13,715
779
Get a couple of brass nipples and make an adapter. The injector return lines are 3/16".
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Yea i thought about that but i've never seen one that small. I'll check around a little more, thanks for the sizing.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
#8 x 1.25 x 4 JIC ( A/N ) will hook to the heads for return lines and is very clean.
thats basically a 1/4" ID is probably less but still bigger than stock
the return of the cp3, i posted long time ago? dont remember now.....then just make a block or T system:)
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Where are you talking about on the heads?
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
So i'm gonna bring this back from the dead. I'm ready to hit the buy button on the fittings i'll need but was just wondering if anyone had any pics of their return line mods.
I'm going to run -4an to 4mm barbed fittings from each return line, then put a T in the center down by the CP3, then run new 3/8 line back to the cooler.
I figured if i'm running all new feed lines i might as well do the return too.
Stupid word doc. Just click open.
  • fittings.doc
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Are you talking about the turbo return lines or the fuel ?
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
Your going all out on that line. Have you looked around for pricing? silicone intakes some of it is kinda pricey.
I was just going to cut off the return line and use a bead maker and a clamp for the line going into the head. but now thinking I might steal some of your list and just use barbed Ts.
My OE return line hits the Ybridge so gonna delete the FPRV and run soft line all the way back.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Well I needed a fitting for the oil drain, then i saw that their fittings will only work with their line so i have to buy line, then i needed a new fitting for the turbo. So my $40 order got to $176 pretty damn fast. But oh well might as well do it right the first time.
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
Haha yeah it adds up quick.
they are just AN fittings. and braided line. I know Jegs/summit has their branded stuff that is cheaper.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Well didn't order from them, i found everything at McMastercar for like half what they had it for. Also I've got more 1/4" line here at work than i know what to do with, so i'm just gonna run a new return line back to the cooler. I think I should be fine with 1/4" line rather then 3/8", i'm not returning much fuel anyway.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Can anyone tell me what the sensor on the return line does? It's located on the driver side just before it exits back to the tank.
13,715
779
There are some tables that reference fuel temp. I would put it somewhere if you can.
