Any part numbers? 2001 lb7. Stripped mine on removal.
AubleAK New member Aug 5, 2011 781 0 0 30 Glennallen, AK Sep 20, 2012 #1 Any part numbers? 2001 lb7. Stripped mine on removal.
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Sep 20, 2012 #2 AubleAK said: Any part numbers? 2001 lb7. Stripped mine on removal. Click to expand... http://creaturesofthenightperformance.com/Injector-Return-Line-Bolt--P2361039.aspx
AubleAK New member Aug 5, 2011 781 0 0 30 Glennallen, AK Sep 20, 2012 #4 Burn Down said: Did you get it out Michael? Click to expand... All 4 of them wanted to strip, i got 2 out with vise grips. Im going to grab a torx bit from napa today to see if that wont help break them loose.
AubleAK New member Aug 5, 2011 781 0 0 30 Glennallen, AK Sep 20, 2012 #5 ripmf666 said: http://creaturesofthenightperformance.com/Injector-Return-Line-Bolt--P2361039.aspx Click to expand... Thanks!
AubleAK New member Aug 5, 2011 781 0 0 30 Glennallen, AK Sep 24, 2012 #6 ripmf666 said: http://creaturesofthenightperformance.com/Injector-Return-Line-Bolt--P2361039.aspx Click to expand... Do you have the part number for the return fuel line itself?
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Sep 24, 2012 #7 aubleak said: do you have the part number for the return fuel line itself? Click to expand... 97188733
