resurface heads?
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
what do you think, do i need to resurface the heads before i install them?
thanks!
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
i didn't check with a straight edge. im going to get them resurfaced tomorrow. don't wanna chance it. i think this is why i was loosing coolant. the metal is definately indented
ripmf666
15,123
14
47
Wentzville Mo
Mine looked about the same and i cleaned them up,with 2+2 and a 3m scotch pad did not rub hard and most of that was sealer that came from the gaskets.
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
whats 2+2? i used a scotchbrite pad. i got 99% of the gasket material off. i actually have grooves perpendicular to the cylinder diameter. the gasket has radius ridges.
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
I'm not being a wise-ass, how did you go about doing this?
snap on di grinder with a aluminum hog bit. then polish with a sanding "drum/roll" kit( i guess you could call it) from summit. sanded from 80 to 120 to 400
matched the exhaust ports to the gasket along with the exhaust manifolds. smoothed out the radius turn and factory casting defects. opened up the valve bowls on the exhaust side
hope i explained in an understandable way
