Going to finally do it! Does anyone know what they gained hp and or et wise from adding just the second pump? Not changing anything else. Truck holds 22000 with 3200 pulse right now. Just trying to get an idea. Thanks fellas
Good luck. Your rods are not going to like that.
Yes unfortunately and they are reallyyyyyy gonna hate the 100 over injectors I'm Fixin to throw in it :roflmao: just gonna run a super low pulse width and pray for the best haha
How hard have you pushed it
Just adding my second pump in and not changing anything else i picked up 1mph and .10 in the 1/4. The throttle repsonse is a thousand times better than the stage3 i was running by itself. I have to be very careful how much more fuel i add now as my engine is 100% stock and im running dual cp3s/60% injectors and a batmo s475. You wont be disappointed with em.
how many miles do u have on this setup?? im so ready to pull the trigger on some injectors/turbo, but i want to get away with using my stock engine,im not even gonna stud the heads
It can be done.
i went from 544 to 604hp with the second pump. I too have bent 8 stock rods with NO studs just stock head bolts.
