Always hot bud... The oil suspends particles in it, so if you let it sit, some of the bigger stuff falls out and into the bottom of the pan.
If thats all the more your driving it just let it go another 1000 miles or so then pull one.
Your iron is not off the charts alarming but it is elevated which makes me suspect a bearing going out. The iron will scrub away on the soft bearing causing elevated copper & a climbing iron count. If your iron drops with the next sample & your copper stays elevated, then maybe a engine oil cooler is the problem.
The reason I asked if any work had been done to the engine recently is because some people will use antiseeze on bolts that are in contact with the engine oil. Well some antiseeze is made primarily from copper & will show high copper on a oil sample
