REPLACING INJECTORS....Star brand from standard products for 2008 LMM only $800?!!
vincefmx
Jul 13, 2012
11
Is testing return rates an easy job yourself or can it be done with efi live? I will try to contact Tony....thanks hondarider!
vincefmx
Jul 13, 2012
11
Well guys, return rate on the injectors are all good....came up to Taylor AZ to Williams bros. great people and probably the most knowledgable shop in AZ I've found. Looks like its time for a lift pump, they have the FASS in stock here.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
What all has been done to the truck? If you fill out your signature it helps others t/s for you. I don't think a lift pump will help a rough running engine...
vincefmx
Jul 13, 2012
11
Will fill out my signature...your right that would help out! As for the vibration/roughness...got her up on the dyno an the driveline was all over the place....u joint was half gone on one post! Should solve the vibration;)
vincefmx
Jul 13, 2012
11
I suggest to anyone who has this same issue to go to a shop with a dyno capable of producing a load and gettin the code to trip, then check injector returns immediately after, once the fuel is hot enough the return rates magnifies, and the truth is shown....one bad injector on drivers side, time for a recall from gm on their pos fuel system!
Burn Down
Sep 14, 2008
7,092
Boise Idaho
It's a Bosch fuel system, not GM and one bad injector in 162,000 is not the end of the world... Just be glad it's not a LB7, they get really expensive to repair. I feel that injectors are wear items and only last as long as the quality of service and fuel they have received.
dmaxman06
May 25, 2011
493
morenci az
not to be a dick but williams brothers is in snowflake not taylor i know its not a big deal being as the two towns are right next to eachother but no need to confuse anybody lol
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I agree. Just be glad that's all it was.
6,024
HA! buy an LB7 then get back to me on that recall :roflmao:. i think your doin pretty good bud :D
