Help: Replaced filter, started, died
JerryL
Feb 9, 2010
27
Emporia, Ks.
Hi I'm new to this site mostly because I've never had any trouble with my 2002 Chevy Duramax.
I just replaced the fuel filter for the second time since buying new. The first time everything went smoothly. This time I purged the air and it started fine for just a few seconds then quit. So I verified a second time that all the air was out and cleaned up diesel a second time. It still won't start after about 20 seconds total crank time. Also, I hear a motor running like maybe the fuel pump but that's in the tank, right. The motor I hear is in the front center of the engine.
Any ideas?
Thanks,
Jerry
Lb7KID
ZoomZoom
Jan 24, 2010
274
parker,colo
sounds like maybe youer cp3 pump?? this is only the 2nd fuel filter on the truck?? since you bought it barnd new??
try to fill the filter with fuel then put it on trun the key for 15 sec an try it again maybe see what happens:confused:
JerryL
Feb 9, 2010
27
Emporia, Ks.
I went and gave it one more try. This time I also gave it full throttle. I must have just been too impatient. She's a purring like all good Duramax should. Thanks! Signing off soon. Got to get up in 7 hours. JerryL
Lb7KID
ZoomZoom
Jan 24, 2010
274
parker,colo
it the injecton pump sorry man i cant spell to good haha. the lb7 motor witch is in youer truck 01 threw 04 an a half has prob with the injetors an the fuel press reg that seem to be the biggest threat to them some times win you change the fuel filter it easyer to poor fuel in it befor installing some older techs dont like this idea. haha im paid flat rate so i dont really care the faster the prime the better. but glad to hear its up an running again!! come see us again there always atleast 5 way smart ppl around here just read some post and you will learn somethen new:thumb:
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
:welcome6: FYI our trucks do not have an in tank pump, nor a helper lift pump from the factory..
Fill our your signature in the user cp.
They just need to crank alittle to push the air out, but I'd rather have that then a low pressure injection pump were as you'd need to crack the injector lines to push the air out. Next time don't be afraid to crank it a couple times.... Change your fuel filter every other oil change :thumb:
JerryL
Feb 9, 2010
27
Emporia, Ks.
Thanks for all the replys.
Larry, my weekend begins on Thursday also. However my 10-hour days suck.
BombDoc, yeah it's stock though I fantisize about better mileage and/or more towing power with a chip. I'd probably be happy with the power of the newer models. I pull a 26' 5th wheel with an 18' ski & fish behind that. Can't wait for spring.
x MadMax, thanks for the education. Unfortunately I don't know many specifics about diesels because fortuantely I've had zero trouble with my truck. I've rebuilt a few gas engines and done almost all of my other work but not trannys. What and where is the fuel pump? I heard something running. Used my screwdriver and it sounded like inside the front of the engine.
You mentioned changing the fuel filter every other oil change. For me that's every 10K. Why so often? That thing is such a pain in the butt to change that I don't even do it on the scheduled 30K. Is there a better tool than my band type oil filter wrench? I'm thinking about getting another band type and cutting the handle shorter.
Thanks to all for all your interest and replies!
Jerry
Dazedandconfused
Lost in the diesel smoke.
Jul 26, 2007
225
Nothern Ky
Buy a strap wrench and use that. Every other oil change is when i change my fuel filter. Last change had around 10K on it and truck was running like chit. They like clean fuel and without have a pusher pump it keeps the injection pump from working so hard.
JerryL
Feb 9, 2010
27
Emporia, Ks.
Fuel Filter
Where do you get your fuel filters? My first one was from the dealership. WOW$$$. My second was a Hastings from the farm and ranch supply. Never again. It's just a little longer and therefore harder to put on. I fussed a bit in the process. {:) I'll get a strap wrench. Thanks for the advice. Gotta go. Dinner and a relaxing evening with my sweet lil lady.
13,715
779
The easiest way to change the filter is to pull the passenger's side inner fender. Takes about 2 minutes at the most to pull it out then the filter is right there in the wide open. I wouldn't go more than 15k miles on the fuel filter.
You should also change the spin on filter on the transmission (assuming you have an Allison) the same time you change the fuel filter.
The only fuel pump on the truck is the CP3 high pressure fuel pump. It is located in the valley at the front of the engine buried under everything on the top of the engine. It has two parts to it. There is a low pressure gear pump that pulls fuel from the tank, through the fuel filter and into the pump. It then pushes it into the high pressure pump where it is pressurized to 23,500 psi in your LB7. From there it is fed to the fuel rails that feed the fuel injectors. There is a fuel pressure regulator, or fuel control actuator depending on who you're talking to, on the CP3 that sometimes makes buzzing noises after the key is turned off.
