Ok, I appreciate it guys.
Mike, what do you mean that the shim isnt tight enough? The FPRV that God himself tightened?
I did tighten it as much as possible. I was getting afraid to damage anything if I tightened it more. Or are you talking about the amount of shims? I ended up using all 3 which put the thickness around .80 mm. Or do you think there is an o-ring not seated properly like on the fuel filter itself ? Meanwhile Im searching the site on how to do bottle test. (Found it.. Ill try it tomorrow)
Josh, I decided after reading many posts on many msg boards, to go ahead and shim it since I do eventually want to build up the HP. Not to mention it is a cheap upgrade. If the valve isnt popping open, then your saying there has to be some kind of leak possibly with an o-ring? Other than the fuel filter o-rings, purge nut on top, where else is there a possibility of leakage? I dont show any signs of fuel on the outside of it.
I forgot to mention earlier that when the low fuel msg comes on , the truck starts to fall on its face. Like lack of fuel (Obvious
As far as the messages, I dont mind as long as its not damaging the truck due to a simple fix. I understand the increased stress from racing. I drag raced gas for years. Im trying to get enough to have a daily driver that has "NO" problem taking out most of the Dodges running around here. The only reason I have the power pup, is that I had it on a Ford 6.0 Van I used to own. Once this problem is resolved, I figured on replacing the lift pump.
I have a 30 day warranty from the used dealership, and Im wondering if its worth taking out the shims, programmer and let them try to resolve it before the time is up? Just in-case there is a faulty pump, etc.
(Thanks for bearing with me guys. I moved over from a 6.0 Power Joke) Im learning as much as I can on these Duramax's.
