the hardest part is figuring out how to get the dash bar out of there. You have to have take the vents out. just get behind them with a flat blade and then give an easy pull. look into the holes and you will see a relase "tab" to push and then slide the bar out, both sides at the same time. The rest is pulling stuff off. there's 4 screws I think. It's been while, ICR.don't forget to take the light sensor out of the hole if you have it. Half a turn and it will drop out.
