Remove or lower lift help
Fatboy
I need a $$ tree!!
Feb 15, 2013
75
Newnan, GA
Looking for some advice on which direction to go. I would really like to get my truck back down to stock height for ease of use. I currently have a Fabtech 6" wide track lift that was already installed when i purchased the truck. I took the bolts all the way down on the keys and I have nearly flat CV angles. My debate is to remove the lift all together or get a set of 1-3" drop keys and lower it down until the CV's are completely flat. Checking from center of the hub to the bottom of the fender I am approx 3" higher than a stock 2500 right now. I would love to go to 265's but my rims are 9 inches wide so I will probably go to 285's from the 315's that are on the truck now. Any experience/suggestions are welcome.
Fatboy
I need a $$ tree!!
Feb 15, 2013
75
Newnan, GA
Also, if i go back to stock i need to weld the ear back onto the frame. I am assuming that i can make my own with a channel and two angles to fab the mount for the diff.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I recently put the drop keys in mine. Running them half cranked it lowered my front end another 1.5"-2.0"
Cognito sells a replacement bolt-on diff ear, so all you would need to weld is the stock crossmember back in.
Fatboy
I need a $$ tree!!
Feb 15, 2013
75
Newnan, GA
Hey Steve - Do you have any pics of since you lowered the front? Did you end up with negative CV angles? What tire size are you running?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Still running the 305/50's. My angles are slightly negative at rest now.
I don't think I have any pics of it yet, maybe a video from the side from this last trip to the strip. I'll look around.
