Not sure if this is the best place to post it but ill try. My buddies dmax 03 LB7 busted the rear housing, we have been looking at a 01 Lb7 and wondering if the rear housing would work for the 03. If not mike what do you recommend.
ya one rear u joint is toast! and what do you mean changing in truck mike? we already have it out and the transmission is still in the truck?
Wow thats good info i would have tried doing in the truck also.If you try and change the extension housing while the trans is still in the truck you will fail. Trans needs to come out and stood on its nose to do it successfully.
Its actually a torrington bearing in the trans that will fall out of place, major carnage will ensue!!!!!
and that always happens?? or does that just happen sometimes, i don't mind taking it out but i can only assume when we get it out it will get built lol
How lucky do you feel? Did you read my post above? I didn't say you might fail.
haha its not my truck so not overly worried, but i will recommend the pulling of the tranny, how do we know if it is already out of position?
