Rear Diff
Juice Burner
May 10, 2016
SoCal
I am wondering what differential to go with the g80 ain't working.
I will be driving in LA traffic , towing , some off road , and it does rain sometimes in SoCal.
Truck has down pipe , 4 in exhaust , EFI Live , and Inglewood Trans.
Should I rebuild replace stock , do the dodge mod, powertrax no slip,
Or ?
What is everyone running ?
Thanks
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I replaced my blown up g80 with the dodge AAM tracrite unit. Brand new they're $670, plus bearings.
So far at 1200whp, it is doing way better than the g80 ever did.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,495
476
Central OH
AAM tracrite here also. Off road will be the only downfall (if you want to call it that) if you've never driven a vehicle with a helical limited slip before.
Smoother operation, hardly any parts to wear out, no clutches to burn up. Seemed like a win in my book.
Dozerboy
4,892
470
TX of course
If you wheel you need a locking diff not a limited slip like the dodge.
I've heard good things about Detroits options.
N2BRK
2,054
371
I'm running the True Trac - love it!! Night/Day performance compared to my g80.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Question, which is the preferred TrueTrac, don't these have a different bias..? If at some point my G-80 bites it which one is optimum.? I have read about the Torsen type carriers which this based on but what are the pro's and con's of the two below.?
$746.00
40099548 Chevy Dodge AAM 11.5" Rear Helical Limited Slip Differential 30 Spline
http://www.drivetrainamerica.com/40...Su-D6O_PqhetEZcmNr8-MpBB9mmueF0BD0hoCQyLw_wcB
$881.51
915A568 Detroit
http://www.drivetrainamerica.com/91...ip-gm-chevy-dodge-11-5-aam-rear-differential/
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
$746.00
$881.51
915A568 Detroit
Found some info, any feed back from anyone using either one.?
http://www.duramaxdiesels.com/forum/showpost.php?p=732219&postcount=17
http://www.duramaxdiesels.com/forum/showpost.php?p=732218&postcount=16
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,495
476
Central OH
Detroit, Yukon, dodge, aam, liberty(DHD)- Mark can get them all.
He was very helpful, thank you again!
I've never driven one with a truetrac, but supposedly they will spin both tires easier because the bias ratio is different. But on the other hand, I've never found a solid source that listed what the ratio was for both the AAM and Detroit version.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
$746.00
$881.51
915A568 Detroit
Opinions, need to change the fluid, pull the cover and inspect the Gov-bomb-80 and need a backup plan if it is not OK. Opinions on the 3:1 as opposed to the 2:1 bias..? The truck is a 2x4 and no off roading or 1/4 mile runs in the future..
Ridin'GMC
I like red
May 20, 2010
638
20
MA
You'll be fine with the AAM tracrite. The Detroit is more geared to aggressive drivers with offroad.
550
I got a 3:1 eaton true trac in my 79 malibu love it..
Ive thought about putting it in my dually. With rear axle weight and throttle needed to start out in a turn... dont yhink it would go well.. i can tell when the G80 is locked or not.. oversteer is extremely noticeable
