to just put airbags in place of your coils.
Help me out here. Can you recommend a set-up or manufacturer? I've never really considered this but it makes sense.
Can you run air bags and drag race legally?
well basicly what you would would do is make a mount for the lower arm, cut the spring pocket off and weld in a mount for the top of the bag.
OR you can just get a Shockwave which is an air bag/shock combo and bolt that right into your shock mount.
BUT if you're 4wd it will be a little trickier. in that case you would need to run the bag off the upper control arm. at that point you might be getting in deeper than you want to.
and yea i don't see any reason why you wouldn't be able to race w/ bags. it's just a 4 link with adjustable suspension
Nice. Those are some fancy valve covers.
