Raw fuel smell in the cab
Mr.Duck
Dec 1, 2012
3
Fella's I was told this was addressed, I searched and I failed.
I have an 06 LBZ and after running for a while and stopping I have a raw diesel fuel smell both outside the truck and inside. I check the lines and there are no leaks and the fuel economy has not suffered. I am running lift pumps (Kennedy) and EFI live.
Any guidance?
Thanks
Mr.Duck
Dec 1, 2012
3
No leak at the filter housing, some residue.
Exhaust is normal.
Fuel smell stronger on drivers side, which leads me to believe rubber fuel lines around the tank.
1slowmax
The break is over
May 9, 2012
283
Sin City, NV
Check your oil level is it over full? Sounds like a injector went south. Check balance rates and do a bottle test. Check the fuel lines and look in the valley of the motor to see if it dry. Let me know
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,196
360
At Da Beach
Inspect your return lines, the plastic T's that feed the returning fuel from the injector to the main return line can crack and leak...
Mr.Duck
Dec 1, 2012
3
So after a real good inspection this is what I found
Balance rates good
return lines intact
Block dry, except by the filter housing.
So I went back to the filter head housing.
After I got off the hiway and could smell fuel I stopped, popped the hood and checked the filter head housing.
There was clear (non-dirty) fuel seeping on top of the housing. I quick rebuild and now it's all good.
Thanks for the suggestions :thumb:
