Ran the truck in my sig dry about 100m away from the fuel station. Was able to get it pushed close enough. Got it to run for 5 minutes but still had to haul it home that night.
Bled the return lines, bled the banjo fitting on the top side of the FICM. Bled the schrader valve by the alternator. Even bled a few of the accessible injectors. and both rails. Truck has a FASS 165. Filters are primed. Truck will NOT fire on diesel. I pinched the return line. Disconnected the FCA. Truck throws an intermittent P0335.
