LB7: Rail PSI ?'s
PACougar
2,105
41
El Dorado Hills, Ca
28 psi is way too high. You shouldn't need more than 10-12 psi. I run mine at 12 psi. My fass said it cam preset at 8 psi...i put a gauge on it right out of the box and it was idling at 3 psi....i adjusted it to 12 psi and have never had an issue. Checking the lift pump pressure is a good idea.
The higher the pressure, the less the flow. Your lift pump is set up to flow 95 gph at probably 8 psi. Crank the pressure up to 28 psi and now your pump may only flows 40 gph.
put a gauge on it and set it to 12 psi and call it a day.
Because pressure is a measurement of restriction it doesn't exactly work like that. Even if you set it at 28 psi as the injection pump draws more fuel i.e. creates less restriction the pressure will drop. Technically the lift pump flows the most fuel at 0 psi.
JJK-
May 18, 2014
Utah
I'll get a gauge installed.. Can the psi be regulated via a regulator screw or does the spring need to be switched out?
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,215
365
At Da Beach
Only on the lb7 and LLY do you have to keep it around 8 to 10. The LBZ and LMM benefit from and can handle the added pump pressure. Mine would go all the way up to 30 before it started to lope. I have set everyone I have ever installed on a lbz or lmm at or above 25 psi...
I somehow missed this is an lb7 though, my bad. Lack of sleep from my 2 week old must be getting to me...:eek:
JJK-
May 18, 2014
Utah
I took the truck out for a few WOT tests and noticed I'm getting 19-20psi of boost. Not sure that this would have anything to do with the rail pressure, but I'm sure it is effecting all the coal I'm dumping and why it's not cleaning up. I'm thinking about pinching off the hose on the waste gate to see if it helps out the boost and cleans it up, of course this would only be for test purposes...
JJK-
May 18, 2014
Utah
I pinched off the waste gate, well at least part way, my vice grips are very small, and it hit 24psi according to my insight. I recently read that the insight reads boost from the map sensor and the map sensors are scaled at 22-25 psi, can anyone confirm this? If so I'll have to hook up a manual gauge to get an accurate reading.
Dirtymaxx03
3,109
Yes the ECM only reads up to like 24 or 26 psi iirc. Drop $28 on a boost increase valve and lose the vise grips lol
JJK-
May 18, 2014
Utah
Yep, for sure. I'll order one tmrw. The vice grips were temporary :)
Now if I can get my rail pressure figured out I'll be set.. Thanks..
Harbin_22
3,858
Southern Indiana
Sounds like it has too much pulse in the tune. It is probably smoking because it is losing rail psi from too much pulse. Log it or ask your tuner how much pulse it is. Maybe they didn't adjust for the bigger injectors.
Harbin_22
3,858
Southern Indiana
That is completely unnecessary. I run 12#'s from AD 165 with the stock pick up and made almost 1000 without losing rail pressure on 2 stock pumps.
JJK-
May 18, 2014
Utah
Good suggestion.. I'm going to his shop tmrw to log it and check a few other things.. Thanks!
JJK-
May 18, 2014
Utah
Any idea what my pulse width should be approx at WOT?
