LMM: Rail pressure
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Is anyone having luck with controlling the fuel rail pressure on an LMM? I'd like to be able to bring pressure up sooner to help with my bigger nozzles, but this table isn't correct to begin with. At 720RPM idle speed I see 30 MPA when up to operating temp, not even close to the 60MPA shown for the area I'm idling at. Cold start never gets that high either.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Have a look at the Pulse table too, its off should look like this stock.
This is from a excel I made
Ross said it will be fixed in next update.
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Mike, I read you're post on EFILive forum about the pulse width table and was aware that the labeling is off. Are you saying that the labels are incorrect on the rail pressure tables also?
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
The rail pressure table are not correct. I just loaded a tune into my truck with 30MPA additional across the board, on every rail pressure table. Check rail pressure at idle before and after loading the tune and it is the exact same, 30MPA.........
