Scale is completely linear.
We run 4600 lbz'sfrom Andrew. They equate to 400% he has said. My math puts them at 485%. But he doesn't like to use percentage. Accurate way to measure is the flow rate. On our flow chart, ea injector ranges from 4520 to 4620, hence the model name '4600'.Has anyone found out at what pressure the S&S injectors quit flowing fuel?
Also, what do LLY S&S "4600s" equate to in % over? I have 400% overs on the way for my dyno tuning session and just curious what pressure to stay away from.
Andrew = S&S. I can give you his number if you have questions. I'm not sure if it's listed or notIs Andrew no longer at S&S?
Our injectors will literally shut off just shy of 30k.
Sent from my XT1585 using Tapatalk
The only way to keep it from happening is to limit rail. I have nailed it down to that via probably ten failed runs at the track and then on the dyno.I don't mean to sound like an ass, but has that been replicated on a flow bench? Just an easy way of isolating the issue, that's all. I know you mentioned this in an other thread a few months ago...
What rail sensor are you using?It’s not an ECM problem. I can guarantee you that the LLY ECM is perfectly happy commanding, and seeing 240 MPA of rail pressure. Have dozens and dozens of logs of my truck doing just that.
Has Andrew ever ran those injectors on a test stand at those pressures?
Glad to see you stuck with it and got it figured out , I hope to see you out there with Caleb when the weather warms up ! Good luck !We run 4600 lbz'sfrom Andrew. They equate to 400% he has said. My math puts them at 485%. But he doesn't like to use percentage. Accurate way to measure is the flow rate. On our flow chart, ea injector ranges from 4520 to 4620, hence the model name '4600'.
Our injectors will literally shut off just shy of 30k. I had pulled my hair out trying to figure it out one pull at a time in 2016, but then was able to duplicate it on the engine dyno in spring of 17, to figure out where to cap the pressure.
I never meant to insinuate it was a problem with the Ecm,
I have similarities to his issue before we figured out how high we had to scale the tables and how to taper things off
If you have a sensor capable of reading the pressure what is the highest pressure you should put in an LLY?
