you guys are missing the singled most important thing.
At least in Wisconsin.
The Cop DOES NOT HAVE TO USE THE RADAR OR PROVE YOUR SPEED. They are trained to be able to judge speed by sight. And that is all they need to give you your ticket.
The radar is there to help them but in wisconsin they dont always have to use it or show it to you to prove you were speeding.
So basically one of our cops can walk up to you and say you were doing 80 in a 65 write the ticket and your pretty much screwed. Because by the time you go through the hassle of battling it in court it isnt worth it and even if you do the judge often times rules int eh cops favor especially if you have a record. The only thing you can hope for is a reduction on the initial court date which is common around here.
Now the worst thing in wisconsin is our points system. Its way worse than the fines. You get 12 points on your license. And if you loose them, you loose your license. A ticket from 11-15 over is a 4 point ticket IIRC, so 3 times you get caught doing 78 down the interstate and bye bye license. not to mention they are ususally around $250.
so praise your radar detectors all you want. but around here they do you no good.
