Racing Rims
jmaz268
Lead from the Front
May 20, 2010
2,895
40
Springfield IL
Well I guess i screwed the pooch when I put on the lowering spindles. i can no longer run a 16" rim anymore. So was wondering if you guys knew of any resources for a lightweight rim. I'm pretty sure i can run an 17" and above.
My 20's mounted are 90 lbs each, so for reference.
looks don't matter, just wanting something light.
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
get some BMF's im at 56lbs/each for my set up :D
arent the h2's light like the pyo's or are they heavier?
rmallen30
861
15
hillsboro ohio
if he used the mcgaughys spindles they do not clear the lower ball joint and castle nut you have to use a spacer which i wouldnt recomend for racing
Ryan T
1,007
CA
dont give away the BMF seceret!!:D mine are about the same, my truck is running 12.40s on 20 inch BMF wheels, they are super lite.. 20x9 S.O.T.A.
jpowel29
780
Bentonville, Arkansas
Real Racing Wheels. Very Strong and Very Light. Not cheap though. You can order whatever width and backspacing you need.
jmaz268
Lead from the Front
May 20, 2010
2,895
40
Springfield IL
That compay sells the their 33lbs rims in a blank.....how the hell would i get em cut......i have a hard time finding a place to get my truck aligned lol.
BUST'EM 504
1,047
what about the lmm rims dont they have a 17" those should be fairly light
my eagle alloys weigh 128lbs fu%#ing tarded
