How many would be interested in a 4l80 that could handle 2000lbs of TQ?
is there a market for a OD tranny that bolts up to the d-max?
I thought mike said something about the overdrive on it being weak?
Allison input shafts made of 4340 do not live at 1,000hp. Nasty proved that. 4L80E shafts made out of the same material can't live as they do not have the heft of the Alli shaft. IMHO
Ben
There was never a 400TH with L/U.
4340 as a base can be made into 5+ grades a few are 300M vacum formed M300, mirage, and other well known billets, the difference is the heat treatment it gets......BIG difference beteween metal grades.
the stuff that comes in the alli is junk! no question there, it's big and beefy but the strength to wieght ratio is way off compared to a much better grade.
the th400 can be used in our trucks, it just depends on the kind of rpm you can get, obviously it would only be for race only applications.....but it would work as would the PG, again limited to the weigh of the truck and the rpm avalible.
the 4l80 is the best choice for the big truck guys cause it has a OD and it has proven itself behind monsterous power levels.........to date almost 2000lbs has been seen but there is still room for improvement.
the shafts are not the issue, it would be the drums or the carriers, being the drums have been addressed, that leaves only the carriers to be left on what might break.
in a 6-800hp truck it would work like a dream, behind a full size truck.
Diesel drag trucks may be able to push the 1200+hp mark if there light enough, but that has yet to be seen with TQ #'s over 2k time will tell........
Build a Duramax with the 4L80 and prove me wrong.
I built the 4l85 in Diesel 5's Grand National with a Duramax and it is holding. The car weighs 4500 lb and has 500 hp or so and the tires keep spinning at will. This is why it's still alive. Try this with 7000 lb and double the hp and tq and something is going to give when the tires hook. Nothing breaks as long as the tires are spinning.
