Quick question
showman1018
Jun 23, 2015
11
I'm new to the tuning world of diesels i have owned them for years just never hopped them up and recently I started to hook up my 05 gmc 2500hd I have put in 30% injectors 3'' down pipe 5'' exhaust efi live tuner and tracion bars oh and put head studs in too. Just curious what kinda hp I'll be pushing and if there is something else I should do im shooting for around 650 to 700 hp. Any help will be appreciated
Sent from my XT1080 using Tapatalk
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
You have a lift pump and who did your efi live tuning? Also whose injectors did you install? Do you have a stock intake or did you replace that? That kind of hp is border line for a stock rod motor, 600-650 is about it, some bend below that my first truck made about 540 hp to the ground and I bent all the rods.
Slowmax
Build what others' won't
Aug 3, 2013
468
United States
Do you have a stock transmission still? If so with max effort ,and or stock trans tunes 450-500hp and not for long.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
650-700hp will require a lift pump, modified cp3 pump, larger turbo or compounds, built trans and good tuning. After that the motor will be on borrowed time.....
Edit: if you are still stock trans now and it isn't limping I can't see you being much over 400hp
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Do you want real 650-700 or just the ability to brag you have that power. There is a lot of generous dynos around to get you those numbers with less mods. But then the track times will make you cry. Dyno numbers are a joke.
showman1018
Jun 23, 2015
11
All the work is being done by Austin diesel performance out of Marne mi I had a superchip in it and I did experience limp mode a few times not always but if I was around 80-90 mpr and was still in it hard it would go into limp mode but not always. But yes I have a stock trans and am worried about it but I'm taking baby steps the main reason I had done what I did is I needed injectors anyways and I had a bent valve so I had them stud it while they were in there under advisement from a friend. And yes I want real power not he said she said.
13,735
804
Step 1 is to build the trans then add a lift pump and better tuning. That should get you in the neighborhood of 500-550 if everything else is in good shape.
13,735
804
I was told up to 600
Not even close. If you're lucky, you might be able to make it last for a while in the 400 HP range, but I wouldn't count on it if you drive it very hard at all.
showman1018
Jun 23, 2015
11
Not to be sarcastic but what guy with a modded truck don't play and that sucks but I appreciate all the advise I'll start looking for a trans I guess lol I get my truck back Tom and now I'm scared for my trans lol never ending
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
These are the c1 clutches out of a stock 6 speed that I pulled apart. Truck is making 420whp...
What they looked liked.
What they are supposed to look like.
showman1018
Jun 23, 2015
11
I found a trans for a 6.6 and want to build it up what kit do y'all recommend
Awenta
4,090
CT
There's still life in those
Awenta
4,090
CT
Contact one of our vendors and pick up a Suncoast kit. They'll take care of you. Or do yourself the favor and have it built by a trusted builder.
1,944
Who is "Austin Diesel Performance"? I thought I knew most of the Diesel shops in Michigan, but havent ever heard of them.
If they are the ones who told you a stock Alli can hold 600rw and that 650 is ok on a stock bottom end, then RUN from that shop.
Max Attitude
11SIX
Mar 7, 2012
814
Caledonia, MI
Ditto. I live about 35 minutes from there and this is the first I have heard of them too. If thats the info they give then run. I would also suggest to not have Merchant build the trans fwiw.
Max Attitude
11SIX
Mar 7, 2012
814
Caledonia, MI
How did you bend a valve?
