Hello all,
I'm a new Dmax owner, and I have always been kind of "anal" when it comes to keeping my motor(s) clean, on any vehicle I've owned, however, this is the first Dmax I've ever had, and I do NOT want to mess anything up! Anyway, I have tried searching for an answer but couldn't find one, my question is what is the best way to clean the engine, would I be safe to use the pressure washer at the local "wash and go", without using direct pressure, keeping the engine running, and covering the electronics with plastic bags as best I can? Do I need to make any special provision for the Turbo? I've always tried to keep most of the water out of my alternators, but aside from that is there anything else I should be concerned with, or special "tricks" to do? My concern is getting water where it shouldn't be, disconnecting electronics, electrical shorts, etc.. Any advise, or input, would be GREATLY appreciated! Thank you kindly!
Jeff
Jeff
