Question for everyone running Caltracs!!!
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Quick question for anyone and everyone who run Caltracs whether on your DD or race truck! Where do you keep yours adjusted at?
On my truck I have the rear overloads removed and have heard that you take a chance with axle wrap with them being removed so hints why I went with the Caltracs. I keep mine adjusted to where the pin is barly on top of the leaf spring at all times but because of this I get a rougher ride in which I am not worried about. My main worry is the wear it might create against the leaf spring as well as wear and tear on the Caltracs and leaf springs themselves. I know I could adjust them all the way up to where they are no longer touching on the leaf spring and only adjust them down on race days, but wanted to know how y'all are running yours...
Any help and comments would be greatly appreciated so I have some more knowledge. THANKS!
jnieberlein
Secret Squirrel Diesel
Aug 17, 2009
689
West By God
For about a year I ran mine with them off the spring about 1/4" really noisy I thought and axel hop seemed bad, for the past few months I adjusted them to touch the spring then about 3/4 turn more (preload) don't seem as noisy and feel better under acceleration, daily driven street truck
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Exactly what I was looking for :thumb:
Most people and a few friends have said simular... I heard from the get go that the Caltracs were noise and they def are but well worth it... I noticed on Sunday when I was looking at them and messing with them I had a slight indent on both sides where the pin had been sitting and knocking up against the leaf... Wasn't to excited about this and worried me :confused:
paint94979
Beer Nazi
Sep 18, 2006
11,715
I dd mine and run a piss load of preload... Keeps them quiet downside is it is a bumpy ride but I'm used to it
TLyons90
Apr 22, 2013
1,631
Greenville, SC
Alot of preload for DD sounds a bit much but everyone has there own opinions and 2cents... I guess I have nothing to worry about then! :thumb:
jkholder09
Jan 8, 2012
1,188
Maryland
matt at cal tracs told me to adjust as follws:
With truck on level surface adjust bars until all play is removed at eyelets and then 1 full turn of preload.
I did mine this way and was very happy with no wheel hop and good drivability mostly.
It did seem to kinda buck more with a trailer on, but I never changed the adjustment and I am sure the weight of a trailer did change the angle
TLyons90
Apr 22, 2013
1,631
Greenville, SC
I have debated calling then to get a little more info. So you actually tow with yours like that as well? Just seems like so much wear and tear on them but suppose that is what they are made for!
jkholder09
Jan 8, 2012
1,188
Maryland
I tow other trucks on a trailer sometimes, but usually its not used for a truck.
If I towed all the time I think I would adjust them with the trailer on maybe and see what happens
I also noticed if you launch and the truck sorta pulls to a side you can tighten that side maybe 1/4 turn and it seems to straighten out.
Maybe My imagination on that as well.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Mine are set up like this, and work well for DD and towing, although I have helper bags as well, so when the trailer goes on I level the load and the preload out to be like it is when unloaded.
TLyons90
Apr 22, 2013
1,631
Greenville, SC
I run preload on mine too:thumb:
Sounds like this is the route I am going to go if all other race trucks are! :roflmao:
Ive gotcha! I have thought about trying that as well... Another situation I was thinking is when you have a half tank of fuel or above that side would be considered under more preload then the opposite side as well and might cause pull...
Haha you cheat you cheat! :D
Duramax5
duramax freak
Sep 15, 2011
417
West Texas
I clamped my overload to the rest of the leafs to hit the track n its so much smoother under full throttle. rides a little bumpier but i'm used to it. been pulling an enclosed all week n it works great!
