Anyone else install the PVC block off plates? Is it difficult?
PCV reroute takes about 10 minutes to do, easy
Thanks, are most kits relatively the same? What kits have y'all used or recommend?
FYI Guys LML PCV's are 3/4" hose and there is only one barb, on the driver side valve cover. 5-6' of 3/4" fuel hose works great. It is not the same as 04.5-10 trucks.
You will also need a blocker plate for the inlet horn. Merchant makes a nice one.
You can cut the crimped ends of the rubber hose on the factory lly pcv plumbing and reuse them. 5/8" hose slides right over the barbed fittings after the crimped OEM hose is removed. Same thing as buying the reroute fittings without the spending money part.
