Pump Rub Question
Tano
Jun 8, 2013
243
San Angelo, Texas
So lately I've started to noticed a thud coming from under the cab of my truck when i take off from a red light or stop sign.
It does not do it if i take off from a stop nice and easy.
If I take off giving it alot of throttle it will make a repeated thud 3-4 times one after the other.
I took a look at my transfer case and noticed the Rear Output Shaft Seal is leaking and probably has been for some time now, there was a line of old oil going from one side of the truck to the other from it slinging it out.
I opened the fluid fill bolt and fluid started pouring out so i'm guessing it's good.:confused:
I have been reading up on pump rub and am having trouble understanding it.
If my transfer case still has fluid then i dont have pump rub?
or does it not start leaking until pump has already been rubbing and caused a hole?
There is no other leaks on my transfer case other than the Rear Output Shaft seal.
Any and all information would be appreciated.
ryan415
Oct 24, 2012
371
860
Check and see how much play is in the slip yoke when you move it up and down. There is a bushing inside the case which commonly wears and will cause the output shaft seal to leak. It should have very little movement.
Tano
Jun 8, 2013
243
San Angelo, Texas
I will in the morning but I guess my main question is what could be causing the thud that i experience when taking off?
ryan415
Oct 24, 2012
371
860
The bushing can make noise but you'll usually hear it when putting the truck in gear.
SmokeShow
6,818
Lawrenceburg, KY
Most likely its that slip yoke sticking on the splines. As suggested, grease those splines real good, replace the seal and hopefully you'll be good to go.
Tano
Jun 8, 2013
243
San Angelo, Texas
Alright thanks guys. I went ahead and ordered the pump rub kit with the replacement shaft seal I'm Gonna go ahead and put the kit in if there's not already one and do it all at once
Tano
Jun 8, 2013
243
San Angelo, Texas
I bought cv joint grease. Got to looking at it and the carrier bearing is beat to shit so I guessing that could be the cause. I'm trying to post pictures but tinypic.com is not working. There's a lot of play in the carrier bearing it definitely needs replaced
Tano
Jun 8, 2013
243
San Angelo, Texas
picture.php
picture.php
Tano
Jun 8, 2013
243
San Angelo, Texas
How big of a deal do you think it would be to change that sucker out?
Doesn't seem to bad. I'm about to goto oreillys and see if they have one
There is 2 different sizes at oreilleys
A 1.5 ID and a 1.3 ID
Is there a way a can tell without pulling it off?
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
If you have an air hammer and cut off wheel removing the old carried isn't bad.. I've not found a way to tell which one so I always get both and take back the one I don't use.
Tano
Jun 8, 2013
243
San Angelo, Texas
Not a bad idea. Hopefully will get around to swapping it and the output seal Monday or Tuesday. Saturday I ended up just changing out my lower power steering hose and man it was a pain in the ass.
