So lately I've started to noticed a thud coming from under the cab of my truck when i take off from a red light or stop sign.
It does not do it if i take off from a stop nice and easy.
If I take off giving it alot of throttle it will make a repeated thud 3-4 times one after the other.
I took a look at my transfer case and noticed the Rear Output Shaft Seal is leaking and probably has been for some time now, there was a line of old oil going from one side of the truck to the other from it slinging it out.
I opened the fluid fill bolt and fluid started pouring out so i'm guessing it's good.
I have been reading up on pump rub and am having trouble understanding it.
If my transfer case still has fluid then i dont have pump rub?
or does it not start leaking until pump has already been rubbing and caused a hole?
There is no other leaks on my transfer case other than the Rear Output Shaft seal.
Any and all information would be appreciated.
