LBZ: pulls hard at idle
jcm
Dec 15, 2012
14
I know ive been driving it like this for months and still haul with it but I'm thinking of selling for a 3500 and I cant sell it like this
jcm
Dec 15, 2012
14
I just want everyone to know I finally got around to changing the converter and it did fix the issue
jc1843
Sep 27, 2009
228
86
So Calf
If the converter clutch disintegrates, it can drag like it is locked up, and send clutch material through the cooler line, and block the inlet of the radiator heat exchanger.
Fluid will not circulate and the trans will run at a higher temperature. You can check this with a thermo heat gun, or remove the lower line at the radiator and check for debris.
You can check fluid circulation-- if you remove the top line where it connects to the trans-- slip a hose on the tubing and start the engine-- should be full flow. Don't run very long, just a few seconds.
jcm
Dec 15, 2012
14
I went with a dacco performance billet converter. The 2011 one is on back order and I waited months for it and gave up and found this one for about the same price.
