Hello I have a 2007 lbz 4wd automatic Chevy and here's the issue. It pulls hard at idle like the converter is not disengaging. Do y'all have any ideas on what the cause might be?
If you're not going to do the trans buy the 2011 Duramax converter.If it is the converter should I go back stock? If not which aftermarket do you suggest
The 2011 stock converter?
yeah its your tcc dragging. pain in the ass, watch your temps.
Definitely sounds like a bad converter.
It's not possible for an Allison to lock the tcc in 1st gear correct?
Not necessarily, but it could be.
