pulling the motor
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
I have the drivers side valve cover bolts off but I am not sure what to do with the fuel lines, they run through the valve cover, should I undo them @ the valve cover? and leave the rail there? I just dont want to make the wrong decision!
Also I was going to remove the bridge between the intake but it looks like because of the lower stud mounts I am not sure that it will come off? TIA
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
but in what sequence? should I undo the line @ the end of the fuel rail and then each one that goes through the valve cover? or does it not make sense to undo the fuel rail?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I undo the rail and loosen the inj lines on the rail and completly remove them on the valve cover side
Jeff before you do this make sure its nice and clean on the valve covers as you can have crap go into the injectors JMHO
KEVINL
1,431
Phoenix, AZ
I didn't remove the glow plugs except the one by the oil dipstick tube
If there are no head bolts in the way of the injector you can leave them Return line needs to be removed
Remove the High pressure lines completely
The Y bridge has a slit on the bottom so it can be pulled out with the studs in there just loosen the 10 mm bolts
